It is currently Mon Aug 11, 2025 9:15 pm
PostPosted: Fri Dec 04, 2009 11:57 am
Has anyone ever experienced or heard of FP cold checking like nitro?
tim...
PostPosted: Fri Dec 04, 2009 12:00 pm
Tim if the shellac has experinced harsh heat then exposed to below freezing it can start checking but I have never had an issue. It seems the harsh heat makes athe shellac overly brittle once it hardens bak at a cold temp. But this is pretty rare to have happen.
PostPosted: Fri Dec 04, 2009 2:55 pm
First name: joe
Last Name: kelly
City: glasgow
Country: uk
i had this happen once and i think i may know what caused it .....to start with i was using a rubber to put the shellac on so i was using an oil to lubricate the rubber....but then i decided to spray build and buff .........and a week or so later it had the most crazy cold dheck effect i have ever seen i think it maybe the oil trapped under the surface and its making its way out........does this have any resemblence to your situation tim?
joe
PostPosted: Sat Dec 05, 2009 8:24 am
First name: Coe
Last Name: Franklin
City: Decatur
I had this situation with the first guitar I built 3 years ago.
I really thought this had something to do with the build-up being awfully thick, and the temprature extremes that I had to deal with back then. BTW, I french polished in late summer and didn`t notice anything until about December. It did get cold, but not below 45 degrees.
I thought I was one of the few to have this happen.
Funny thing about it is that my daughter asked me if I could make that "pretty patina" on her hope chest, and had to admit that I didn`t plan on it in the first place, and didn`t really know how it happened.
It does give it character, though (or should I say done by a real character).
Refinish it? No way. That guitar is done and I have no reason to change it at all, being #1.
Coe Franklin
PostPosted: Mon Dec 07, 2009 9:26 am
joe
Truth be told, I have never had a FP finish "cold check"... yet. I just wanted to know if anyone had ever had it happen. based on your responses, sounds like it is plausible though. I did subject a FP (top only) guitar to some temps in the teens and it never checked BUT it was in a room where the temps came down and back up very slowly and the finish was very thin. It wasn't subjected to an abrupt change which usually will make nitro check.
tim...
